back plate air leak???
joneser4u
Waverly
How do you check for or know if you have a leak on the back plate behinde the easy start of the pro.15?If I do how do I fix it? Is there a o-ring or something?
I dont know the guy at my HS told me the pro.15 was known for air leaks around the back plate?
I don't know what seals the plate on your engine but even if the gasket or o-ring (whatver is used) doesn't seal you could use a light coating of Form-A-Gasket. Just be carefully not to over apply and only cover the contact areas to keep the material out of the engine case.
