back on the road or in the air
browners9
wapella
i have a few questions first. tires i have a set of imex swamp dawgs on the t-maxx (glued) these things vibrate so bad is there anything i can do about that second i can't get this thing to stay running at an idle it will last about ten to fifteen seconds then it dies it takes about ten pulls to get it fired up again temps running about 240 when I'm taking it easy but when i get into it and start playing real hard it runs up to about 275 280 (temp gun) god smoke trail and for the last ? how do you post pix from photobucket to this page?
As for the photobucket question, use the IMG tag that is below the pic. Simply double click the tag and then ctrl-V in your post. As far as your tuning questions, I'm no pro at tuning but the idle sounds like it's loading up. You may want to lean your LSN and richen your HSN just a hair. Bash it for a few mins and then re-temp/post results.
getn dark here but guna go at it after work tmorow
Anything new? havent heard anything in a few days, so i figured i would check in.
got back at it tightened down the lsn fattened the high side this thing does back flips well it did any way stripped out the slipper gear took motor off found a bad bearing on clutch plus the clutch was about shot guna get back together tomorow
tires
As for your tires you might try gluing small fishing weights of I believe they may make some just for rc purposes on the inside of the wheel. when you spin the wheel the heavy side should stop at the bottom then apply a small amout of weight to the oppisite side, or use some thing like this. http://cgi.ebay.com/R-C-Wheel-tire-...ryZ44028QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i hat these things when your really getting on it the tires baloon up go all out of shape the they get hard to control
what is a good setup
you could go with a proline 40 series rim and tire in 14 or 23 millameter if you get the racing tires they are low pro so less tire side wall to balloon + they are wider so it will make it more stable just my thoughts.
