wm6405
Hey Guys, it has been a while since I've done anything related to nitro r/c cars. I got a savage x 4.6 about 3 years ago and ran it hard for a year and then pretty much put it down and forgot about it, but after going into the garage and remembering how much fun it was I had to get it back up and running, so I took it to my local shop and he told me I had almost no compression in my engine and my engine had pretty much been burnt out so I got a brand new engine installed and began to break it in today...
Breaking it in gets me really nervous because I don't want to hurt my engines life from the start but hopefully I've done okay so far. When I put the first tank through it I had a little trouble getting it started (This is while it was idling on a box). At first I could only get it started for a second and when I would remove rotostart and glow plug it would shut off and eventually I got it running for a little longer but I had to just give it a little jolt of gas to get the engine running (hopefully that is OK, I couldn't get the engine to turn over without it) and then it would run longer and I let it burn through a tank...My only 2 concerns are that it was
1) Dripping a little brownish/red liquid out of the exhaust onto a towel I put under it. I can't remember if that was okay or not. Does that mean I need to lean out the fuel a little bit because it was getting to much??
2) I was letting the car idle without giving it any gas, but the wheels were still spinning considerably fast (maybe like 7-10mph) which just seems way too fast. I would tap the brakes every few seconds to keep them slowed down and I had the idle trim turned down on my transmitter...I don't think it's supposed to idle like this so do I need to turn down one of the screws on the engine (I was never good at tuning my car so I don't really know all this stuff).
Again, It's been a while since I've done anything with my truck, and even then I wasn't very good with all the technical stuff. I just enjoyed going out and bashing with it...But this go around (with a new $200 engine) I actually want to actually take good care of it and make it last longer. I never really knew how to tune it and maintenance it past a certain extent...So if any of you guys can help me with my breaking in process question, or have any further advice on break ins I'd appreciate it...also If you have any tips on tuning and what kind of things I can do to keep my engine healthy and running longer It would be greatly appreciated also.
Thanks!
Thanks!
