An issue with my Savage x ss brushless conversion
Dbnjzb
Rockaway, NJ
So I got a Mamba Monster 2 ESC and a Neu-Castle 1515 2200kv motor. I'm used the conversion kit from HPI to strap these bad boys in along with a little rigging. Everything looks good. Also, i'm using 2 Bias 3S 50c 5000mah lipos. I'm thinking this thing should rock!!!
1. It sounds like metal is grinding when i try to drive it like its the pinion and spur (although the mesh seems perfectly fine to me...i could be wrong.)
2. It barely moves along. I know it should be flyin!
If it at all matters I have Big Joe's on it, a 44 spur, and a 20 pinion.
I really want to get this thing out and movin so I'd appreciate any help you can give. Thanks so much!
DB!
Is your motor getting hot? How did you set your mesh?
Motor wasn't getting hot. I did just eyeball the mesh. Thank you.
Try switching the positive & negative leads, and reversing your throttle control on your transmitter.
This I will try, thank you. Although I think I might've done this already. I'm also going to check my solder connections because I'm assuming a bad solder connection wouldn't let much power go through, right?
DB!
I keep coming back to your #1 symptom the grinding sound, was this a new truck or one with some use on it that you converted over to brushless?
It was my Savage X that I converted. I've inspected all the gears and all look good. Although, I did just notice the spur is slipping even when I move it by hand hmmmm...maybe I need a new slipper pad. Hmm
Change the slipper pad or tighten the slipper nut down some more, after that start checking your driveline including diffs.
I am going through the process of upgrading a Savage X to an XL Brushless with the castle creations mamba you listed - which motor mount did you use? Where did you mount the ESC? did you leave everything else stock Savage x? I bought a roller from ebay so I am planning to stretch it with the XL plates. How are the big joe wheels holding up. Would love to see some pictures of your setup?
