I ran my savage yesterday and can't get the tuning right, it's leaning out when give it ful throttle, and when the throttle is released, it takes awhile before the rev goes down. And even if i richen it up it still runs the same. The temp reached upto 350F.
After opening up the engine to check for airleaks I discovered that it was comming from the center of the backplate (where the starting shaft goes out. It was wet with oil), while inspecting I noticed that the bottom side of the conrod(the one facing the backplate) was stripped and the tiny minute pieces of aluminum was all over inside the engine. Sad to say that it also gave me a loose piston and sleeve.:stickup: this is the rebuilt engine that i recieved from hpi. This is also the case why i sent my old engine back to them.
I can't figure out why the conrod's side gets shredded when the temp gets to that temp, or is it just a coincidence that it happened that there is really something wrong with the engine.
Sorry for the long post. please advice......
tnx
arnold
tnx
arnold
