air in fuel pipe
jrowbotham
Shropshire
my car starts fine when I start it for the first time in a day and it drives well, but after a while it loses power and doesn't move. it then cuts out. when I look at the fuel pipe, it has air bubbles in it. when I blow on the air pipe connected to the fuel tank, the fuel flows to the carb and than shoots back down the fuel pipe again.
can anyone help??
It sounds like there might be a leak in the fuel line. Try replacing the line from the tank to the carb.
can anyone help??
I think that your mixture is too lean and after the first run your engine is so hot it won't make power.
Try richening the high speed needle and see if that solves your problem. When the engine gets super hot it will vapor lock which causes the fuel in the fuel line next to the carburetor to vaporize and become a gas. This could be what is causing the bubbles in your line.
Lee
