Air Filters
big boi
hi guys i need a new filter should i get the 2 element o.s. or the paper ae:contract: which one is better?!
Hey, I would go with the O.S super air cleaner (2 elements).
It is really safe for your engine. If the top gets dirts, you have a clean one below it.
Peter
P.S. I run them on all my cars.
that is a good filter - also the Moter Saver filter is great, that is what i use. If u go to the local track u will find that about 99% of the driver are using either the filter i use, or the one somers does.
I use a Motor Saver in both of my cars. It has the two stage filter elements. I would go with foam filters over paper.
Motor saver all the way.
I run them on every nitro I own.
They aren't cheep but worth every penny.
Pay me know or pay me later.
I have one problem with the motor saver. because it has that metal mesh on the outside, that tends to get some oil on it from the foam and clogs up pretty quick and cleaning it sometimes takes some work. Other than that, I love them. that is all I use.
mjime - i have noticed that problem too, however i am able to alleviate it by spraying a small burst of nitro cleaner in the element afte each run, only takes a second, and prevents that from happening!
I would do that too, but I get lazy.
So the point here is, dont be lazy like me. Clean you filters after a day of running and you wont have to scrub the crud off like I do.
I love my MOTOR SAVER and have never had a problem with it. of course I keep my car blinging, I disassemble and clean it after every outing
