Don't put it in the tank! If the oil hits the rubber seals in the carb needle area, it can mess things up. Take off the air cleaner and drop a couple drops down the carb venturi. Take out the glow plug and a couple more drops there. Crank engine, or pull starter, or whatever, a couple times. My oldest brother has been using Marvel Mystery Oil for air tools and it has kept his OS Surpass 4 stroke (airplane engine) running for 10 years at least.
For my Savage SS, since the engine is a .28, I use one of those paint mixing syringes, I suck up some ARO into the syringe (about 1 inch of it), and squirt it in the carb, and the rest in the glow plug hole. Too much and the engine can lock up when trying to turn it over. Just 2 cents from a guy with no cents
