After run in, is it esay?
  • Thread starter Thread starter Cyberphreak
  • Start date Start date
C
Cyberphreak
Guest
Hi,
Just wondering, i runnin in my Picco .26 and its a hell of a job, i got a rotostart (Starts everytime now) but everytime i pushin it hard and about to change into second it stops, i ajusting eveythin and gettin there slowly but i was wondering after run in will it start eveytime and will i have to ajust anything? Cause its gettin annonying lol :arrr:
Cyber Phreak
By "running in" I'm not sure where you stand. If you have not gone through the break in, then you should not be getting the rpm to where it would shift yet. As for starting every time, we would all like that and it depends on how well you do the break in and setup of the carb.
I have been known to run nearly a quart of fuel through mine in one run without shutting it down. And it starts everytime too. You have to treat your mill good and break it in carefully.
But to answer your question, once you properly break the engine in (can take from 1/4 to 1 gallon of fuel), it should start easily and run reliably. Check your plug and tune it right.
