I'm going to try and give the best detail possible on this one but It may end up requiring me to make a video.
Several of you guys know about Bryson's Revo that I purchased and got back to running condition and well it seems that it's still not perfect. I'll start from the beginning and end with today.
When I got the truck I decided to drop my 3.3 in it from my T-Maxx. The truck came to me with 15/38 gears, stock tranny and stock diffs. When I dropped my 3.3 in the Revo and took it out for a test run it was running exceptionally well. Shifting was spot on, plenty of low and top end! It ran all of about 2 hours (can't remember quite how long) before I split the con rod in my 3.3 and tore up the piston and sleeve. Check out this post for details.
Yesterday I received and install all my new goodies on the Revo including a brand new OS .21TM! I left everything the same, 15/38 gearing, stock tranny, stock diffs. The only thing that is different was an Integy 3 shoe aluminum clutch upgrade.
I broke the motor in yesterday afternoon, it was pulling wheelies by about the 3rd tank and by the 5th it seemed to be running awesome and with a little but of tuning I figure the shifting issue would go away and it would be pulling wheelies left and right. Well apparently that is not the case.
I made a trip to Hobby Town USA today since my LHS is closed and picked up some new glowplugs, fuel, pull start and tempgun. Made it back to the local track and started tuning my truck. Needles were back at stock and engine was up to running temp. Start tuning the HSN hoping for a nice gain in speed and the damn truck to start shifting into second. 1/2 turn in from stock settings and the truck was shifting but very laggy and very late :\ . I bring the truck in and check temps and I'm already hitting 300 degrees. I'm holding the trigger WOT for only about 3-4 seconds in my passes which is about how long it was taking to shift and reach full speed. So I figure maybe a new motor with different specs, the tranny needs to be adjusted.
So I adjusted the tranny a total of about 1/2 turn in to get it to start shifting better. Its still a bit laggy and the shifting isnt quite persistant. With it shifting properly the HSN is 3/4 in from stock settings and the temps with the body off are around 280, with the body on I'm getting around 310. I richened the LSN from stock about 1/8th of a turn to try and bring the temps down but then I loose some of the lower end and the temps still gradually rise up to around 300.
Keep in mind the engine was sealed before it was even broken in, the carb was sealed (except the neck) and the needles were hit with some TA green slime. I guess I should also throw in there that I was still getting a nice blue smoke trail with the temps being up there and also if anyone has any experience with the 11k carb it seems that tuning is done in much smaller increments on the HSN as you only have 2 1/2 turns out from closed at stock settings. The MSN doesn't seem to need to be messed with and the LSN at stock settings gives you about a 2 1/2 sec kill time when pinching the fuel line.
Can anyone chime in on WTF is going on?
Thanks
Oh yeah and one other issue I am having is the reciever cuts in and out, I think it may be from overheating as I had a piece of foam in wrapped around it and I cut it and only put a piece on the bottom of the tray and it stopped doing it. Later on towards the end of my bashing it started again. It will cut out and if I turn on and off the reciever it works fine for a minute or two then does it again. I changed the batteries in the remote and the receiver packs are brand new.
Thanks
