Ok so... The car is back together and its now on to a few questions I notice when taking it out to start it.
#1 Fixed
#2 I put a single servo on and I think I did it backwards because the direction of steering is swaped. Whats an easy fix? I am assuming its just as simple as taking the servo off and turning it around?
#3 Dun dun dun... tunning. So I got the engine started but I am having a really hard time with it. First problem I noticed is with hitting the throttle... no power. The car didnt want to even budge until half throttle... At which point I can tell the engine is far far far from being tuned right. Now I looked in to what the factory settings on the HSN and LSN are, but what about the idle needle on the 3.3. What the heck is it supposed to be set at?
The engine temps where not getting too hot because I was able to touch the blue cylender head. Usually its a bit too hot to touch. ??????
Next, when I did get on the throttle a bit after messing with the LSN I noticed a bit more power returning HOWEVER a TON of white smoke came out the exhaust. As well as the idle sounded a bit loud compared to what I remember when I started it up my first time. Now I am assuming that the LSN has little to nothing to do with the car once its moving... so I am guessing I needed to mess with the HSN. I went through one tank just sitting around messing with the LSN and idle needle trying to get power back and get the idle sounding right but ill be honest... I am lost.
I did notice a bunch of brown oil looking crap coming out the exhaust for the first few minutes I am sure you know what what it is?
I am going to print out a little flow chart I have but still... something says I am not doing something right at this point.
#4. Engine temps. What are they supposed to be for a fine tuned 3.3? I dont have a temp gun yet but its on its way. I really would like to know.
#1 Fixed
