a bit of info on savage x
twisted
i just bought the upper adjustable control arms.you can get from 0 degrees to 3 and prolly 4 if you shave the plastic down a bit.
the stock savage x uper arms are 3 degrees.
I think he is saying onthe stock savage X upper arms are at a fixed 3 degrees whereas the adjustable ones get you 0 to 3 degrees and maybe 4 with some dremeling...
I'm sorry guys but hpi instructions give you a gap chart withthe adjustable arms and i set them to 3 degrees according to the instruction and then measured them up aganst the stocks so i would assume the stocks were 3 degrees...wrong. after i putthe adjustable one on the truck and measured the camber i had 0- 1 degree positive camber....thats wit hte adjustable arms screwed all the way in.
so in order t get any negative camber i had to trim the plastic a bit on the adjustable arm so i could screw them in closer. i made another post about this problem on here.
sorry for all the blabber..ths is just got me pulzeld.
