I could do it in a matter of minutes at this point lol. Take the front a rear body-bumper mount things off. There held on with 3 2.5mm screws inbetween the shocks (rears will be held on with 3 also but are at the base of the mount, right under the pipe). Then you have axcess to the top hing pins. Remove skids and pull hing pins. Un screw the pillow balls, and everything should fall off. Then at the top of the drive shaft by the bulk head, there will be 1 per drive shaft 2mm screw. Remove those and the axles will fall out. Then replace eveything with the new parts just the way the old ones fell off and your good to go. Hope this helps,
Bryson
