6V sub c hump pack
craig911
Bristol, England
hey guys
I'm very tempted to get a 4.2Amp battery pack click me its at hobbyking for £9 then whatever shipping is
Specs:
Category: Sub-C
Capacity: 4200mAh
Discharge: 10C constant / 15C burst
Voltage: 6.0V
Chemistry: Ni-MH rechargeable
Weight: 340g
Dimensions: 69x46x43mm
Discharge Plug: JR style
will this fit in the savage battery box or would i need to make some modifications to the battery box for it to fit
I'm thinking of using this as I'm using 3 servos as i have reverse fitted and 24+ leds fitted on my truck
or could someone point me to a comparable hump pack
quick edit:
this pack is Sub C so 1/5 scale as opposed to the normal 1/2 AA cells used in smaller models
I highly recommend this upgrade for any monster truck. Longer run time, improved response from your servos, you can't go wrong.
As long as its specified as a receiver battery pack it should fit your battery box.
just made a quick edit i forgot to mention this is a larger size pack using sub c cells as opposed to 1/2 AA cells hence the will if fit question
