4907 Won't shift into second gear
dashrom
RCTalk Rookie
I have now that it has warmed up I have retuned my truck. It is now not wanting to shift into second. I have not messed with the transmission at all. I was however way out of tune from what I thought was right. So I went back to factory specs and started over. LSN seems to be right according to the pinch test. Not sure what adjustments need to be made to correct this issue. Advise please.
If you are at factory specs, it is going to run on the rich side. You will need to lean the hsn a little before it will shift. Do you have a temp gun, if so what engine temps are you running? Did it shift before you put it up for winter?
Mine wen't through a stage of not wanting to shift so i put some oil in there and not a prob since. And my engine runs at about 130.C is that normal ?
