craig911
hey people
so i picked up a 3 speed kit for my truck it was old stock so ordered the high speed gear kit for a grand total of £34 for the upgrade
what gear ratio would you guys recommend as i can't seem to get it to shift reliably
i'm using wheels that are around the same size as the hpi goliaths but with a wide off set and are wider are about an inch wider than the terrapins
engine is a mac star .28 turbo plug 35000 RPM max
my current is 20/47 but i'm changing that now
i have a 47t 49t and 52t spur gears
i have 13t 14t 17t 19t and 20t clutch bells I can't use the 13t or 14t clutch bells even with the 52t spur as it rubs on the dual fiber disk brakes
I'm going to drop down to a 17t bell but can't decide between 47t or 49t spur but would like some input from someone that has experience with the 3 speed
i found the base settings for it
2nd gear. full in. then 4 1/2 turns out.
3rd gear. full in. then 3 turns out.
