3 shoe clutch for the stock TRX25R engine
ByPS
RCTalk Racer
Czech Republic
Hallo everybody,
I need your help to choice correct 3 shoe clutch and flywheel for the stock TRX25R engine.
I have to use the stock 14T and 15T clutch bell, but I want to change clutch type. I do not know how to determine which 2 shoe clutch will fit the TRX25R engine and the clutch bells by Traxxas.
Can you anybody help me or can you give me some tips?
With thanks.
I bought the Team Integy 3-shoe conversion kit for mine, it was for a 2.5 t-maxx but its working great. Also, it has aluminum shoes that grab better than the stock clutch........hope this helps......
Nitrobuzzard
Super, both are what I need. Thank you all for the tips.
If somebody have expirience with someting else, please let me know.
Thanks guys.
Nitrobuzzard
Look at this:
http://integy.automated-shops.com/c...p_catid=29&sid=4wSJJh1ESM0d4zv-50105546326.9c
It's Integy 3 shoe for which you gave me the tip.
But in the kit is not spring. Do you thing that is possible to use spring from current stock clutch system or not?
If not, please be so kind and give me tip which spring i can use. I have readed Integy pages but nothing about it I found.
Thanks a lot.
Thanks for answer, it sounds good.
Is possible to buy only shoes? I plan to buy it in nearest future. Me and my friend have problems with stoch clutch. After 3 liters the clutch do not gram and engine after shifting is rev like without clutch and starting from stay is not waht if Revo was new.
Sorry for my english :o(
ByPS, You might want to check your slipper clutch also.
OK, thank for the tip. I will take a look at slipper clutch.
Slipper clutch i never have disassembled, only little tighten, but little bit.
How i can check good function?
When I put my foot infront the revo to stop him in going forward and give WOT then the cas is stopping, engine soudns like "i want to go up" but the cluctch do not grip.
In normal situations where the car si moving around parking lot or goind on garden, the mdoel is going nice. No wheelies in this moment.
Any tips for the sipper clutch?
