3.3 wont shift
3.3max
RCTalk Qualifier
I have ran about a half a gallon through my tmax and it will not shift can someone explain how to adjust or a video it would be greatly appreciated thanks
is it lacking power,once i had a high speed needle that would lean up on me by its self and once it got too lean it wouldnt shif also way too rich can have the same effect,also could b a loose slipper.
check your slipper, your mill may be hitting the right RPM's, but if your slipper is too loose, your drivetrain is not seeing the right RPM's to shift.
So all I had to do was lean it out a bit it was still set to factory settings and would poor out smoke and unburned fuel so problem solved thanks guys
I'm going to jack this thread cause I dont want to start another one with the exact same title. a friend of mine his truck will not only not shift but it wont even go fast enough to shift when I say that I mean the engine will be whaling but the truck hardly moves it goes about 2-4 mph it came out of the box with this issue I dont know what to tell him. any input would be greatly appreciated
Have you checked the slipper clutch?
one can replace a slipper a thousand times but if it is not adjusted proper it will never work
