cerpndicular
- Racing
brand new 3.3 only has had a little under a gallon through it (includeing breakin. Ran great at first made enough power to snap axles in high traction areas (older tmaxx upgraded to 3.3) and shred the back half of my body from wheelies and what not so i was pleased. Then it started running like crap. Impossible to get the idle to come down to where the clutch wasn't engaged enough that it was driveing around at about 1/4 throttle without me touching the throttle. starting getting to where it would bog and usually die going into second and the only way to fix it was to run the hsn 7-8 turns out. I've pulled the engine appart but can't find anything wroung with it have moded the clutch a little to try to make it lighter and put on a steal spur those are the only things i have changed since i broke it in. Any ideas? I did find that my hsn was stripped where it goes into the carb but replaced the carb with one from a worn out 2.5 i had laying around that i knew was good but it still had the same problem.
