3.3 help
bassman
I have two buddies with 3.3's and when they start them they run for 2 to 3 minutes and then quit. Let them set for 30 sec and they run good for about a half of tank then quit again. Let them set for 30 sec to a minute and they start and run fine. Temp is around 255 to 265.
go back to factory settings 4 on hsn and 2 1/2 on lsn
cracked fuel tank? i know that if you crash hard enough it will crack the tank. fix? only use two screws to hold the tank.
