Morpheus,
From what I have read, most of the issues associated with break-in problems are from less than ideal conditions "outside"..LOL. The colder the temps, the tougher it seems to be. Some things may need to be added to your break-in procedure if temps are less than say 45 degrees. I am not sure what kind of weather you have in Tx but if it is warm enough, you should not have a bunch of issues with the break in...I have noticed that if you really want to break in in cold weather, there are tips on this board as well as the owner's manual on steps you can take....For example, wrapping the cooling head with a sock or foil....if it runs too hot....then peel a few layers back to expose a few ridges on the "cooling head..." I am in the process of waiting for warmer weather myself....Best of luck with your new rc........
Hawk
