These engines are notorious for getting air leaks around the front bearing.
Every front bearing may leak a little air, because it is impossible to get a 100% seal between moving parts... BUT... the picco's tend to get serious leaks that effect the tune of the engine.
I suggest replacing the bearings after the first gallon if not as you get the engine. At the very least check the bearings once you notice it running eratic.
