25-30 Kg Payload Drone Advise
RamazanK
Hi. I need a hexacopter or any drone that is need to lift 25-30 any payload and it need to flight 8-9 minute with this payload. 5 – 10 km flight range with video transmitter is enough . Autopilot with altitude and avoidance radar are good options. I need a huge drone frame, I couldn’t find. I selected these component:
Hobbywing Xrotor X9 Pro
Skydroid T12
Profuse 12S 21000 mah
DJI N3 – AG or JIYI K ++
Tarot 1w FPV transmitter TL300N4
Can You comment for this components and If you have any options, can You give advise ?
you can't select components b4 you have a designated drone.. I know of Zero drones with that payload amount 66 pounds..
I think you have some major asking to do with whom ever controls the sky's in your location.I know I have to Deal with the FAA flight-rules
Hobbyking do 930mm octocopter frame for less than £20. Unsure of its take off weights but if you’re looking for type of weights I’d say to make your own frame. Easy and very cheap to do. Whatever frame you do chose make sure max take off weight is at least half your load above. So 25kg load would need a minimum of a frame that can take 40kg
