Just thought I'd let Roto Start uses know that you need to keep an eye on the starter housing. My screws came loose and I tightened them as soon as I noticed the problem. Yesterday the engine refused to crank, thought it was flooded at first but removed the plug and still no go. The crank turned by hand with the flywheel. Pulled the engine and found a bad one way bearing and when I cleaned and inspeced the engine I found that the backplate was cracked at the one corner screw hole. Why they designed this cover with only three corners screwed down, is beyound me. I could see that the screw holes were almost egg shaped. This came from the time the housing came loose. I'm trying a repair with JB weld and hope it holds. I also built up the other corners to give more material between the screw and the edge. This would have went un-noticed had the bearing not gone bad and eventually I would have destroyed the backplate.
I need a Picco .26! I also need the money to buy one...
