it can be done - but i wouldnt recommend it. Here is a link to a post about doing the same in an NTC3. The cars are simlilar - so the info should be compatible
My buddy just got the RS41 for 25 bucks,and he wantto throw a Manly Motor in it, and he said "If i can't fit a 351c Ford in it, I guess ill have to settle with a .21"
part number WLF029, available from Bruckner Hobbies, 800 288-8185
it only works with the belt models not the new shaft driven models.
Seems to be the part you need since you have the belt driven version.
Hope I could help.:smart:
I did the conversion with a Racer2 and an XTM 24.7. You need the conversion kit form wolfpack, a manifold and a short 1/8th scale pipe (I used a CVEC). I would recommend upgrading the brakes to the RRP aluminum kit, getting aluminum pulleys and belt tensioners all around. The extra power will tear your car up if you don't.
