freerida69a
My friend brought me out his jato 2.5(i know this is the wrong section but no once checks the other section) and i ran it the first day and was tuneing it and jacked up the idle so it would go like 5mph at idle so it wouldnt die, then i ran it for the night and put it away. i couldnt get it to start within the next 4 days. I'm going to shorten things up here: pulled the engine apart, cleaned everything, carb back to factory settings, rtv gasket on backplate and carb and pinch bolt, put it all back together and it started right up the next day. then after trying to tune it to be able to idle with out dieing it would make that sound of the ez start spining but not spinning the motor, i figured it out and it seams that fule seeps thru onto the shaft and slips the one way bearing, evertime i clean it it will turn the motor over, so whats wrong? also why does it not idle without having the wheels in the air!?
