rebuilt the .15fe, sleeve was "squeezed" by OSRockets-(fast service by the way)
when removing the sleeve, I didnt mark it to the block to replace in same position.
I set the sleeve when the largest cut out was lined up with the exhaust port.
tried new plug, cleaned carb, starter freshly charged and checked with plug in car,needle set at 3 turns(hpi website says 2.5-3 turns for starting). Primed it,
it seems the car trys when I give it full throttle, but can't stay running on its own.
I also tried the needle in small increments- down to 1 turn and then to 4.5 turns while trying to start it.
Could I have put the sleeve in wrong? And there is no gasket/spacer in between the head and block, should there be one?
