Sold / Found 1/10 scale nitro touring car.
Status
Not open for further replies.
aj200415
F/S: 1/10 scale nitro touring car. $180 SHIPPED!!!
This is a 1/10 scale nitro touring car. It was built by another person, but it is basically an HPI RS4 3 evo. It has a different chassis and fuel tank, but other than that, it is the same thing.
Has same features as RS4 3 such as:
A shaft drivetrain prevents damage from pebbles and stones
Full-time 4WD provides great handling on any paved surface
T-15 engine features a large heatsink head, 2 needle adjustments and ABC construction
A limited-slip front diff makes driving easy and predictable
Dual chamber tuned pipe and tube header
A complete set of rubber-sealed ball bearings
The proven Airtronics radio system keeps things under control
The radio transmitter is comfortable to hold and features a battery strength indicater, letting you know when the batteries need to be replaced or charged. The transmitter also features a retractable antenna, steering and throttle trim dials (for fine adjustments to center the servos), plus a dual rate adjustment for the steering! Dual rate is very important because it lets you adjust how far the steering servo turns the front wheels left and right.
Pre-cut foam bumper keeps everything protected
D-Compound X-Pattern tires grip just about everywhere
Adjustable body posts let you fit a variety of HPI bodies
It comes RTR with roto-start backplate, and shaft to fit in any drill.
T-15 engine has little use on it since i have had it. It was ran with 20% nitromethane fuel.
2-speed adjustable transmission
It has head and tail lights hooked up to a toggle switch on the body.
Almost forgot all the extras that come with it:2 extra bottom chassis, 1 extra top chassis plate, extra transmission parts, one speed transmission complete, front and rear A-arms, turnbuckles, extra oil filled shocks, front and rear diffs., linkages, rear bumper, and alot more!
Got to ask but is that a Smartech?
top chassis plate and gas tank is...nothing else is.....i checked it out...i have a replacment gas tank(non-smartech) for it, so not to be worried.
May want to post some closeup shots of the chassis.
can't see much and 200.00 is hard to part with if your not exactly sure of what your getting and can see the condition.
JMHO
thnaks, will do as soon as i get home from school
THis thing has got to go $150+ shipping!!! come on guys, its gotta go.
Status
