ok i have an '03 fr12 non pull start rear exhaust fantom. the carb is rotary (if all that matters). i have found the HSN, you can't miss that huge thing. i also found the idle screw. now i dont know which is the LSN. there are only two other possible screws on the engine and I'm not sure which one is it. i have heard there are engines with a middle speed needle that turn simultaneously with the LSN. but I'm not sure if the fantom has 3 needles.
maybe the third thing that i think is a needle is just a screw, i dont know. ill try to describe it as best i can. if you have a fantom you can probly help me alot easier.
one of the screws that could be the lsn is at the end of the carb. it is where the throttle arm thing is that opens and closes the carb. it could just be a screw that hold that together.
the next one is on the side of the carb. its towards the right on the opposite end from the HSN and kind of low. its just a screw by itself and looks kind of like the HSN but smaller. this is what i think is the LSN but I'm not sure.
i can't take pics sorry my camera sucks too much to take close ups. if you have a fantom like i know fasteddy and a few others do, please help me out.
