Axial has just taken the extremely popular Axial AX10 Scorpion chassis and created a Ready-to-Run truck with two different configurations!
The factory configuration is a 20t pinion with the rear axles locked allowing you to attack the track at full speed. Want to take it slow? All you have to do is swap out the 20t pinion with the already supplied 14t pinion gear and install the front axle lockers (parts also included), this second setup allows you to...
Click to continue
Click to continue
