Axial 28RR Spec1
WoodiE
Kind of good admin
Administrator
Lexington, KY
The Axial 28RR Spec 1 is a .28 cubic inch big block engine featuring a machined cast aluminum heat-sink head for extra cooling, dual bushing aluminum connecting rod, true ABC chrome sleeve construction for durability, and a three needle 9.0mm slide carburetor (including 8.0 & 8.5mm optional venturi’s) with a composite body for better performance at higher temperatures...
READ MORE
