Axial Yeti now available as a kit
axial yeti kit ax90025
The Axial Yeti Kit is finally here! Now you can build your own solid rear axle rock racer with independent front suspension, thanks to Axial being one of those few remaining companies still releasing kit models.
The Axial Yeti kit version will accept standard 1/10th scale brushed and brushless 4-pole systems and most major stick pack batteries.
Axial Yeti Kit Features
  • Adjustable Icon aluminum shocks
  • Universal axle set
  • Heavy duty spiral cut bevel gears
  • Dual slipper clutch
  • Aluminum lower link plates
  • Aluminum M4 threaded turnbuckles
  • AR60 OCP-Axle – solid rear axle, independent front suspension
  • Complete set of decals, clear body and interior tray
  • 2.2″ officially licensed Falken Wildpeak tires
Part #: AX90025 – Axial Yeti Kit
MSRP: $329
