One of the heaviest components on the Axial AX10 Scorpion rock crawler is the engine. Axial has designed the transmission to place as much weight as low as possible the motor still remains heavy. So Axial has developed a new part which will help decrease the weight of the motor by allowing you to run lighter motors, an outrunner style motor.
The Axial AX10 Scorpion outrunner moter plate is sized to allow you to use the small lightweight outrunner motors. The new Axial outrunner motor plate replaces the stock motor plate and can be easily installed. The Axial AX10 Scorpion outrunner moter plate is also made from 2.5mm 6061 aluminum for added rigidity and light weight.
Axial AX10 Scorpion Outrunner Moter Plate Features
- Replaces the stock motor plate
- 2.5mm 6061 aluminum for added rigidity and light weight
- Allows the use of small lightweight outrunner motors to help lower the center of gravity
- No need for any other motor adapters
Part #: AX30490 – AX10 Scorpion Outrunner Motor Plate
MSRP: $25.00
Discuss the new Axial AX10 Scorpion Crawler Outrunner Moter Plate in our RC Rock Crawler forum.
