Associated RC10TC6.2 Factory Team Kit
Team Associated just announced their latest version of their ever popular TC6 touring car platform, the TC6.2 Factory Team. As expected the Associated TC6.2 Factory Team has a number of improvements and fixes making it even better than the previous version such as the upgraded bulkhead, chassis configuration and top plate that allow flex to be optimized by disconnecting the drivetrain bulkheads and suspension mounting systems. The RC10TC6.2 is only 88mm wide and 2.25mm thick, and the carbon fiber chassis remains very narrow, resulting in reduced drag during the hardest cornering.
RC10TC6.2 front end
RC10TC6.2 FT Upgrades
  • 22 ball bearings
  • Cross-compatibility with TC6.1 suspension components
  • Floating servo mount
  • Floating spur gear mount
  • Lightweight rear gear diff and front spool
  • Lower spur gear and top plate
  • Narrow 2.25mm graphite laminate chassis
  • Optimized dual bellcrank ball bearing steering system
  • Updated bulkheads and arm mount system
  • VCS3 shocks
RC10TC6.2 chassis
RC10TC6.2 FT Specifications
Power Source: Electric
Terrain: On-Road
Body Style: Touring Car
Scale Size: 1:10 Scale
Assembly Level: Kit*
Length: varies
Width: varies
Wheelbase: 255mm (10.04in)
Weight: varies
Internal Gear Ratio: 2.0:1
Drive: 4WD
Part #: 30109
Release Date: December 2013
