Associated RC10T 4.1
Associated RC10T 4.1 Brushless
Based on the 7-time National Champion RC10T4, the brushless RC10T4.1 is a fully assembled truck that features many of the components from the RC10T4 Team kit, while incorporating a totally new 2.4 GHz XP3-SS 3-Channel radio system and SHV1504 MG metal gear steering servo. Power is supplied by a Reedy 3300kV brushless motor while the XP SC450-BL electronic speed control with LiPo cutoff provides smooth throttle control. A sealed gear differential improves reliability and allows fine tuning for different track conditions.
Designed by the winningest name in R/C, the brushless RC10T4.1 can be additionally upgraded using a full line of Factory Team T4 hop ups, as well as Reedy and LRP performance parts.
Team Associated RC10T4.1 Brushless RTR Features:
  • Built on the 7-time National Champion RC10T4 platform
  • XP3-SS 2.4 GHz 3-channel radio system w/ SHV1504MG metal
    gear servo
  • XP SC450-BL Brushless electronic speed control with LiPo cutoff, forward and reverse with reverse lock out
  • Reedy 3300kV brushless motor
  • 2.6:1 ratio gearbox with sealed gear differential, dual-sided adjustable slipper clutch, and rubber sealed ball bearings
  • Molded composite low-CG chassis with set-screw antenna tube lock
  • Blue aluminum shock bodies with molded pre-load clips
  • Battery strap with twist-lock thumb knobs
  • Rugged steel turnbuckles for adjustable camber and
    front toe-in
  • Angled bellcrank “co-planar” steering with built in servo saver
  • Vertical ball ends for roll center adjustments, front & rear
  • Pre-mounted tires on white dish wheels
  • Factory finished Interceptor-T polycarbonate body
associated rc10t4.1 chassis
Associated RC10T4.1 RTR Brushless Specifications
Scale 1/10th
Power Electric
Length 390mm
Width 316mm
Track 270mm
Weight 1756g
Wheelbase 280mm
Internal Gear Ratio 2.6:1
Drive 2WD
MSRP: $399.99
