The Associated RC10B4.1 Factory Team Worlds Car kit has all the latest Factory Team features, starting with the +8mm B4.1 chassis conversion. The +8mm chassis greatly improves the overall stability and handling of the buggy making it easier to drive and lowering your lap times. Topping off the +8mm B4.1 chassis is the Pro-Line Bulldog +8mm body.
Other features include the Factory Team 0 degree rear hubs, Factory Team rear ballast weight and the new B4.1 Factory Team Worlds Car setup sheet.
Associated RC10B4.1 Factory Team Worlds Car Kit Features:
- +8mm B4.1 chassis conversion kit
- Pro-Line Bulldog +8mm body
- Factory Team 0 degree rear hubs
- Factory Team rear ballast weight
- New B4.1 Worlds Car setup sheet
- Ball differential with light-weight outdrives
- Pro-Line M3 Holeshot 2.0 rear and M3 4-rib front tires
- Factory Team V2 hard anodized threaded shock bodies with bleed-screw caps
- V2 slipper assembly with high-rate spring for more consistent slipper clutch adjustments
- CVA joints with pin retainer clips
- Durable steel center-drilled front axles
- Suspension mounts for 4, 3.5, 3, and 2.5 degrees rear toe included
- Blue titanium turnbuckles
- Complete set of precision ball bearings
- Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts and much more!
Associated RC10B4.1 Factory Team Worlds Car Kit Specifications:
Power Source: Electric
Terrain: Off-Road
Body Style: Buggy
Scale Size: 1:10 Scale
Assembly Level: Kit*
Length: 385mm (15.16in)
Width: 250mm (9.84in)
Wheelbase: 281mm (11.06in)
Weight: 1535g (3.38 lbs)
Internal
Gear Ratio: 2.6:1
Drive: 2WD
Part #: 9040 – Associated RC10B4.1 Factory Team Worlds Car Kit
