Team Associated RC10T4.2 Factory Team Kit
Team Associated has released their latest version of the ever popular T4, the Team Associated RC10T4.2 factory team kit. The RC10T4.2 kit now comes with the latest Factory Team high performance option parts like the 12mm “Big Bore” threaded shocks, VTS slipper clutch, blue aluminum bellcrank set, and 12mm wheel hexes, just to name a few. Also included in the T4.2 Factory Team kit is the Pro-Line Bulldog body.
associated RC10T4.2 chassis
RC10T4.2 Features:
  • Factory Team 12mm “Big Bore” hard-anodized aluminum threaded shocks with TiN “Gold” 3mm shock shafts
  • VTS slipper (variable torque, multi-plate slipper with three drive surfaces) assembly featuring a high-resolution spring
  • Factory Team 12mm blue aluminum front and rear clamping hexes with hex wheels
  • Pro-Line Bulldog body
  • Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing
  • Factory Team blue aluminum bellcrank set
  • Updated shock towers optimized for the 12mm “Big Bore” shocks
  • Ball differential with light-weight outdrives
  • Factory Team blue titanium turnbuckles
  • Factory Team carbon-fiber battery strap and blue aluminum thumb screws
  • CVA joints with pin retainer clips
  • Factory Team rear ballast weight
  • Complete set of precision ball bearings
  • Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts, and much more!
Team Associated RC10T4.2 Features
RC10T4.2 Specifications
Scale: 1:10
Power: Electric
Length: 390mm
Width: Varies*
Weight: Varies*
Wheelbase: 288mm
Drive: 2WD
RC10T4.2 Factory Team Kit shown equipped with items NOT included in kit: Reedy motor, Reedy battery, LRP ESC, XP servo, XP receiver, tires and pinion gear. Body comes clear. Assembly and painting required.
Part #7025 – Team Associated RC10T4.2 Factory Team Kit
Available: Feb. 2013
