RPM A-arms for Savage and Savage X
RPM A-arms for Savage installed on HPI Savage
For all everyone looking to shed some unwanted, unsprung weight, RPM has you covered! RPM Savage X A-arms weigh in at less than the stock Savage A-arms due to our low profile designs. The low profile combined with the beveled leading and trailing edges of the RPM Savage X A-arms prevents them from hanging as low as the stock versions and allows the RPM Savage X A-arms to ride up and over obstacles versus slamming into them.
RPM Savage and Savage-X A-arms have been engineered to strict tolerances, eliminating most of the slop typically found in the stock versions, also eliminating the need for shim kits to tighten up the suspension. Furthermore, our A-arms are still silky smooth throughout the entire range of suspension travel and the new RPM Savage X A-arms allow all those critical settings to stay locked in place.
RPM Savage and Savage-X A-arms are available in three color options: black, blue and purple. RPM Savage X purple A-arms match beautifully with stock anodized purple parts. RPM Savage and Savage-X A-arms are built from RPM's trademark blend of bulletproof nylons for unmatched durability and performance and backed by RPM's world famous breakage warranty (You break it, they replace it). With strength, precision and awesome good looks, there’s absolutely no reason not to mount a set of RPM A-arms on any Savage or Savage-X truck!
RPM's Savage and Savage X A-arms are sold in sets, including one lower and two upper A-arms. The two upper A-arms give the end-user the option of a stock, zero-degree camber angle in a fixed length A-arm, or a negative two-degree camber angle A-arm. By using fixed length upper A-arms instead of an adjustable style camber rod set-up, RPM has kept the weight of their upper A-arms to a minimum while providing the maximum amount of durability RPM customers have come to expect from RPM parts!
RPM Savage X a-arm colors
Part #: 82002 Right Front or Left Rear – Black
Part #: 82005 Right Front or Left Rear – Blue
Part #: 82008 Right Front or Left Rear – Purple
Part #: 82012 Left Front or Right Rear – Black
Part #: 82015 Left Front or Right Rear – Blue
Part #: 82018 Left Front or Right Rear – Purple
MSRP: $14.95 /set
Discuss the new RPM Savage and Savage-X a-arms in our HPI Savage Talk forum.
