RC Terms
RC Terms is a list of commonly used RC Terms to help both the new and experienced RC racer. The terms listed below is just of the most commonly found and used RC Terms / RC Glossary used throughout the forum, in the R/C pits, or in RC Books/magazines.
A-Arm
The upper and lower suspension arm usually found both in front and rear of the R/C. The arm’s 2-point chassis hinge and single point mount at the hub (which shocks mount) resembles the letter “A”.
ABC
This typically refers to the type of materials used in nitro engines. Aluminum piston, Brass cylinder which as been Chrome plated. This tends to be the most common materials used in today’s engines.
After-Run Oil
Oil which is used after you’re done running your nitro engine. It’s recommended that you remove the glow plug and place a couple of drops of After-Run oil in the cylinder as well as in the carb throat. It’s also recommended you user After-run oil if you plan on letting your engines sit for an extended amount of time without starting them..
Air Dam
Prevents a car from lifting off the track at high speeds, most touring car bodies have an extension or air dam in the front bumper that is designed to keep air from getting under the car.
AM
Amplitude Modulation. This is the type of radio systems more ARR and RTR kits come pre-installed; suitable for most newcomers however more serious racers will opt for FM or PCM radios that are less prone to glitching and interference.
Anti-squat
The angle of caster on the rear wheels. Raising the front of the hinge pins of the rear arms gives a caster (anti-squat) angle and helps to transfer the power more evenly, keeping the front of the vehicle from lifting under heavy acceleration.
ARR
Almost Ready to Run, these R/C’s usually require a minor amount of assembly before they are ready to run.
Ball Bearing
A hollow metal "donut" that uses balls inside to increase the efficiency of a rotating shaft (ie. an axle). Highly recommended as the first option part for any kit equipped with bushings, bearings have become a standard accessory in most R/C kits today..
Ball Cup
This is a “cupped” plastic piece that snaps onto a ball end to provide a pivot point—usually for suspension movement. Using this type of assembly instead of a rigid system allows the cup to pop off in the event of a crash, instead of breaking. Using turnbuckles with ball cups allows for more tuning flexibility.
Ball End
The ball end is a metal ball with a hex and screw threads on one end. A ball cup attaches over the ball end to provide a pivot point.
Battery Elimination Circuitry (BEC)
A BEC is a circuit that uses an electric R/C’s main battery pack to power the radio equipment without the need for a separate receiver pack.
Bell crank
Steering mechanism used in most RC vehicles that consists of two posts joined a link. Each is connected to a left or right steering knuckle with a turnbuckle with one post connected to the steering servo.
Big Block
Refers to nitro engines that are .21 size or larger.
Bleeding
When building or rebuilding shocks, it is necessary to remove all of the air and excess oil. This is known as bleeding the shocks.
Blue Groove
This term refers to dirt tracks that have been smoothed out and packed down along the optimum racing line over time. A bluish tint results from tire wear.
Body Reamer
The body reamer is a tool for creating perfect body post holes in Lexan bodies and other semi-soft materials.
Break-In
A new nitro engine has to go through a break-in procedure to mate the engine’s piston to the cylinder sleeve. This provides a longer life expectancy between rebuilds. Recommended procedures will vary by manufacturer and engine. Generally, an engine will need to be run rich and at no more than half throttle for the first 2-3 tanks of fuel. The entire procedure can consist of anywhere from 3-5 tanks of fuel, depending on the individual engine’s instructions.
Bulkhead
A very fundamental part of your R/C vehicle. Several major components rely on the bulkhead to join them to the chassis. Shock towers, upper chassis plates and suspension arms. Differentials are sandwiched between the left and right bulkheads.
Bushing
A metal, and sometimes nylon, "donut" that supports a rotating shaft (ie. an axle). Most metal bushings are made out of something like Bronze Oilite, a metal that is permanently lubricated. Ball bearings are highly recommended over bushings.
Camber
This refers to the angle of the tires in relation to the ground, as seen from the front and rear of the vehicle. Zero camber (90 degrees) refers to tires that are exactly perpendicular to the ground. Tires leaning toward each other have negative camber, while tires leaning away from each other have positive camber. A general rule of thumb is to have a slight bit of negative camber and to be sure both tires maintain the same camber angle. For the most part you should always avoid positive camber.
Carburetor
Also called "carb" for short. This part of the engine controls the ratio of fuel and air entering the engine. There are two types of carbs: slide carbs, where the barrel slides along its axis instead of rotating; and rotary or barrel carbs that rotate. The rotary carb is most common among RTR kits and is fine for most applications. The slide carb provides a quicker response and is therefore more desirable to the more serious enthusiast.
Center of Gravity (CG)
The higher your chassis components sit above your wheel’s axles, the higher the CG of your vehicle. As a result, it may roll over more easily during tighter turns. Keeping your CG as low as possible will provide a more stable vehicle.
Chassis
Made from aluminum, plastic composites or woven carbon fiber,this is the main platform to which all other components attach.
Clutch Bell
The clutch bell attaches to the crankshaft of a nitro engine and meshes with the spur gear, performing the same function asa pinion gear on an electric motor. Changing the number of teeth on a clutch bell alters the way a vehicle performs. Fewer teeth produce more low-end torque, whereas more teeth increase top-end speed.
Clutch Shoes
Clutch shoes are made from aluminum or a composite material and are attached to the engine flywheel. They expand under increasing RPM to engage the clutch bell that, in turn, engages the spur gear to make the vehicle move.
Comm Lathe
An electric motor’s commutator will wear over time. This lathe is used to cut thin layers of material until the surface is like new.
Crank Shaft
The shaft that the flywheel and clutch bell are mounted to. It is attached at the back to the piston by means of a connecting rod. The up and down motion of the piston causes the crank to rotate.
Crystal
A small interchangeable element in radio systems that determines what frequency that radio will operate on. You will find a crystal in the transmitter and in the receiver.
CVD
Abbreviation for Constant Velocity Drive. A type of drive shaft that uses a ball type set up that functions similarly to a universal drive shaft. Although "CVD" is a trademark of MIP (Moore’s Ideal Products, Inc.) it has become commonly used to describe any drive shaft of this type.
Damping
The rate at which a shock is compressed or rebounds. Most RC kits now contain shock absorbers that are filled with fluid/oil. Without this fluid, the shocks are bouncy and provide very little benefit where control is concerned. By changing the weight of the oil or the type of shock piston, or both, you can change the damping rate to tune your car to a specific track and/or driving style.
Differential
A differential is a unit that transfers power from the input to output shafts. The differential, or “diff,” enables the outside wheel of a vehicle to spin faster and travel farther than the inside wheel during a turn
Discharger
Many battery chargers include a built-in discharging function. A better way to discharge your packs, however, is with a separate discharger that connects directly to the battery pack. One common style looks like a row of small light bulbs.
Dog bone
A metal drive shaft with a ball at each end that has a pin going through the center; the pin fits into a slot in the out drive to transmit drive train power.
Drag Link
A bell crank steering systems consists of 2 posts connected by a bar. This bar is the drag link and is also referred to, by some, as Ackerman link.
Dual Rates
This refers to a switch that regulates the sensitivity of transmitter control input. This is a useful function for many beginners,who tend to over-control their vehicles.
Dyno
Short for dynomometer. A device used to rate and compare electric or nitro engines. It measures things like RPM, torque, HP, efficiency,power, amp draw and some will provide power band graphs.
Electronic Speed Control (ESC)
An electronic component that controls throttle input by regulating the current being sent through the motor.
Exponential Rate
This refers to servo travel that is not directly proportional to the degree of control input. A negative exponential rate makes the control response milder around the servo’s center point, but it becomes increasingly stronger as the input approaches100%.
Fail Safe
If the transmitter’s signal is lost or interrupted a fail safe unit returns the servo to a predetermined position to avoid dangerous runaways. A battery failsafe is a safety feature which brings the throttle servo down to idle as a warning that the receiver battery’s voltage is getting dangerously low.
Fixed Link
Camber and steering links on many RTR (ready to run)vehicles use a non-adjustable link. These can usually be upgraded with turnbuckles as the driver’s skill improves, as he is looking for more adjustability.
Flywheel
The flywheel is the larger metal wheel that sits behind the clutch bell and aids the engine’s crankshaft with momentum and idling. For more torque and smoother idle use a heavier flywheel; for improved top speed and throttle response use a lighter flywheel. On non-pull start model sit also represents how to start the engine with the use of a bump starter or starter box.
Foam Inserts
These inserts are used inside tires to help them retain their shape. Different densities are available for use on different track surfaces.
Fuel Gun:
A rapid fuel delivery system used during nitro races. Generally speaking,they deliver 75ccs of fuel in just a second or two.
Glitch
Otherwise known as radio interference, a glitch refers to a momentary lapse in signal transmission. There are external sources that cause glitches, (like overhead power lines,) but consistent glitching is most likely the result of something in the vehicle itself, such as metal-to-metal rubbing as you might find with control linkages.
Glow Plug
Resembles a miniature spark plug. A glow plug supplies the necessary heat for igniting the fuel/air mixture in an engine. A battery-powered unit sometimes called a glow starter is installed over the plug to heat the small wire filament inside the chamber. After the engine is running, the glow starter can be removed since the wire filament inside the plug is kept hot by the engine’s "explosions within the chamber.
Header
This is the aluminum exhaust coupling that attaches to the engine’s exhaust port. A muffler or tuned pipe is usually attached to this bent piece of aluminum tubing.
Hinge Pin
This is a straight metal pin that connects the suspension arm to the bulkhead,and it allows the arms to pivot up and down.
Hub Carrier
This housing supports the drive axles of a vehicle, and uses bushing or bearings to keep the shaft turning smoothly.
Hydraulic Lock
Also know as hydra lock, the term refers to when the engine becomes flooded with fuel preventing the piston from compressing in the combustion chamber. Engine damage can result if the crankshaft is forced to rotate without relieving the pressure. If this happens remove the glow plug,turn the vehicle upside down and briefly crank the engine to drain the excess fuel.
Lean
When the needles on the carburetor are set such that the engine is not getting enough fuel, this is referred to as running lean. Running too lean may help fuel economy and appear to make the vehicle run better; however,it is also a sure way to shorten the life of the engine.
Lexan
This is a clear, plastic-like material that is vacuum-formed over molds to create different body styles. These bodies are then painted on the inside so that the paint does not scratch off from less than perfect laps around the track.
Linkage (throttle, brake)
Heavy gauge wire is used to connect servo horns to throttle and break controls.
Locknut
A nut that uses a nylon insert in order to better grip the threads of a bolt or shaft and thereby preventing it from coming loose. It is used extensively for axles and other areas where nuts must stay secure, but it may need to be removed frequently for maintenance or repair.
Mechanical Speed Control (MSC)
The MSC is a servo-driven device that uses resistors to regulate power transfer from the battery to the motor as a means of throttle control.
Megahertz (MHz)
Unit of radio frequency. Surface frequencies are75 MHz and air frequencies of 72 MHz, 27 MHz, and 50 MHz can be used for either ground or air applications. However, a FCC license is required to operate on the 50 MHz (am radio) band.
Milliamp
(mAh) This is a rating for batteries. The higher the milliamp rating, the longer the cell can provide power. Currently, most RC batteries range from 1500 to 3300 milliamp hours.
Module used to describe the tooth pitch of a metric pinion or spur gear:
The most common modules are 1.0, .8, .6, and .4.
Muffler
All nitro-powered cars use some type of muffler to reduce the noise output and provide pressure to the fuel tank.
Needle Valve
A nitro engine can have from one to three adjustment needles on the carburetor. They are used to adjust the air to fuel ratio. On most engines, the needle is turned clockwise to lean the mixture (allowing less fuel and more air to enter,) and counterclockwise to richen (permitting more fuel and less air to enter.)
NiCad (or NiCd)
Rechargeable Nickel Cadmium batteries, most commonly used to power radio transmitters and receivers. Also used in stick packs in electric vehicles.
Nickel-Metal Hydride (Ni-MH)
Battery cells that do not have "cell memory" with slightly less voltage than nickel-cadmium batteries.For the average enthusiast this means less maintenance.
Nitro/Nitromethane
This is a fuel additive that increases a model engine’s performance.The ideal nitro content (measured by percentage) varies from engine to engine, but you will typically find 10 to 30 percent on the hobby shop shelf.
NORRCA
National Organization for Racing Radio Controlled Autos. www.norcca.com.
One-Way Bearing
This is a bearing that allows a shaft to turn in one direction only.
Out drive
The out drive refers to shafts that exit the differential on either side and transmit drive line power to the drive wheels using an axle shaft or universal.
Over steer
The condition that’s usually present when the rear wheels lose traction before the front wheels ending up with the rear of your vehicles swinging around through turns. Adjusting shocks, stickier tires or more rear down force are some possible solutions.
Peak Charger
When the battery has peaked, meaning it will no longer accept a charge,this type of charger reverts to a maintenance charge rate, considerably decreasing the chance of damage to the pack.
Peak
The point at which a battery no longer accepts a charge. Energy is then converted to heat that is potentially hazardous and can be damaging to the battery pack.
Pinion Gear
Electric RC vehicles use a pinion gear attached to the motor’s shaft to turn the spur gear which in turn spins the rest of the drive train.
Piston
The piston fits into an internal cylindrical part of an engine called a sleeve and slides up and down during the combustion cycle. The piston turns the engine’s crankshaft via a connecting rod, converting the energy of combustion into rotational torque. The piston and sleeve of an engine are replaceable but must both be replaced at the same time.
Pitch
In its simplest terms, this refers to the size of a gear’s teeth. For instance,a32-pitch pinion gear has smaller teeth than a 48-pitch gear. The number represents how many teeth per inch.
Power Supply
A device that converts110VAC to 12VDC. Generally used to power charging equipment.
· Preload (shock). Adjusting pre load on shock absorbers determines a vehicle’s ride height. It is adjusted either by clip-on spacers or by tension clamps. Threaded shock bodies use a metal ring that is rotated up or down to adjust pre load.
Prototype
A full-scale working model of an original new product or an updated version of an existing product.
Push/Under steer
If a vehicle’s front tires don’t provide enough grip through turns the car will not turn as sharp as it should. It will appear to go straight even though the wheels are turned.
Receiver (Rx)
The servo and ESC plug into this electronic unit in an RC vehicle. The receiver converts the radio signals from the transmitter into servos and/or electronic speed controls commands.
Resistor
The resistor is the ceramic unit on an electric vehicle’smechanical speed control(MSC)that limits the amount of current transferred from battery to motor. It dissipates the energy as heat.
Reverse Lockout
This is an ESC function that prevents accidental engagement of reverse function on an ESC. Reverse is generally not permitted in organized racing, in order to prevent track mishaps.
Rich
When the needles on the carb are set such that the engine is getting too much fuel it is referred to as running rich. If you accelerate from a stop and the engine dies,you are probably running too rich and should lean out the engine’s low speed idle adjustment a little (by turning the needle valve or low-end adjustment slightly clockwise).
RPM
Measurement of engine speed; the number of rotations/revolutions per minute.
Run time
Total length of time a vehicle will run on a single battery pack or tank of fuel.
Servo Reversing
This is just what it sounds like. Radios with this function allow the user to reverse the output of the servo. This is useful when you switch the radio system between vehicles that may use different servo placement or orientation.
Servo
This is the unit that actually does the physical work inside your vehicle. A servo contains a small motor that, when activated by commands from the transmitter,moves the control linkages for steering, throttle and brakes.Some vehicles with 3-channel radios have a third servo to activate other functions, such as reverse or shifting of gears.
Servo Saver
A device that protects the servo from excessive force that could damage its gears. It can be integrated into the control horn or the steering bell crank.
Shock Piston
A small plastic,brass or nylon disk that travels up and down inside an oil-filled shock body.It uses a hole or holes to regulate the rate at which the shock compresses and rebounds.
Skid Plate
A plastic or metal(usually aluminum or titanium) plate that protects the underside of off road vehicles.
Sleeve
The internal cylindrical part that houses the piston in a nitro engine.
Slipper Clutch
This refers to a device found primarily in off-road vehicles that allows the spur gear to slip under excessive load. This feature protects the drive line from excessive wear and, when set properly, makes it easier to drive in loose conditions.
Spur Gear
The large gear that meshes with a pinion gear or clutch bell to provide power to a vehicle’s drive train.
Stagger
the difference between the circumferences on the left and right side tires.In oval racing, a positive stagger means the outside tires are larger than the inside.
Stinger
The small tubular tip on the side of a tuned pipe where exhaust is expelled.
Sway Bar
A heavy wire that attaches across either or both the front and rear of a vehicle’s suspension arms. It is designed to keep equal down pressure on the left and right through turns. When the outside edge of the vehicle is pushed up through a turn the sway bar pushes down on the inside edge to keep the tires on the ground.
Synthesized Receiver
A Receiver,utilizing crystal-free technology, that can be set to any desired frequency
Tamiya/JST Connectors
These electrical connectors are widely used within the hobby. The shape of the female end on the battery and the male counterpart on the electrical component prevent accidental reversing of the polarity, which would create a short circuit.
Tire Truer
On-road racers running foam tires are likely to have a truer in their pitboxes.When the foam donuts become worn or damaged, the surface can be renewed with a tire truer, a machine that operates in the same manner as a lathe.
Toe Angle
When seen from above, a car’s front wheels will point inward when the steering trim is set to neutral. Applies to the rear wheels as well. This provides some degree of stability. Too much toe angle will slow you down.
Top Qualifier (TQ)
The driver who turns the most laps in the shortest amount of time. In full scale racing this is known as the pole setter.
Traction Compound
A liquid substance applied to tires to enhance traction.
Transmitter
The part of a radio system that is used by the driver to control a vehicle.The transmitter sends signals based on a drivers input to a receiver that is mounted in a vehicle.
Transponder
This is a small electronic device mounted in a race vehicle. It transmits a signal to a receiver located at the start/finish line. The receiver records a vehicle’s position and lap times during a race for scoring purposes.
Tuned Pipe
This is an upgrade for any vehicle equipped with a muffler. It is designed to increase an engine’s power output. Different tuned pipes are available for different applications. Some provide increased top speed while others aid off-the-line power.
Turn Marshal
A racer who, after he has finished his race, stands at various spots around the track during the next race to turn over any vehicles that have flipped and to remove vehicles that are no longer operable,for whatever reason, from the race course.
Turnbuckle
This is an adjustable link that has conventional threads on one end and reverse thread son the opposite end. This enables you to make vehicle adjustments without having to remove the link from a vehicle completely.
Universal Dog bone
A universal dog bones is a drive shaft that combines a conventional dog bone and axle into a single, more efficient unit.
Zip Tie
A term commonly used for plastic cable wraps because of the zipping sound it makes when tightened. A good pit box will always have several sizes buried among the hex wrenches and dead glow plugs.
This list is ever growing, however if you have a RC Term you’d like to submit please email us your term and we’ll add it to our RC Terms list.
