Mugen Seiki MBX-6R nitro buggy
Mugen MBX-6R
Mugen has released news of their newest 1/8th scale nitro buggy, the Mugen Seiki MBX-6R! The Mugen MBX-6R features aluminum front upper as well as rear lower arm mounts, 3 differential shaft driven 4WD powertrain and carbon fiber damper stay.
Mugen MBX-6R chassis
Mugen Seiki MBX-6R kit contains:
  • E0429 aluminum servo Horn Set
  • E0177 aluminum Front Upper Arm Mount
  • E0185 aluminum Rear Lower Arm Mount
  • E0188 Tension Rod
  • E0233 Spur Gear 44T
  • E0254 Center Drive Shaft (110)
  • E0329 Radio Plate
  • E0330 Battery Holder
  • E0331 Battery Holder Post
  • E0416 Chassis (+5)
  • E0571 Front Damper Spring 1.5/8.25T
  • E0576 Rear Damper Spring 1.5/8.25T
  • E0838 Steering Rod 52 (4mm Square)??
  • E0903 Muffler Stay
  • E1012 Wing Black
  • E1032 MBX-6R Body (Force body by Bitty Design)
Mugen MBX-6R body
Mugen MBX-6 Features:
  • 3 differential Shaft Drive 4WD
  • Universal Drive Shafts
  • 15mm F/R Damper Sets
  • 4mm F/R Carbon Graphite Damper Stay
  • Aluminum Front Lower Arm Support
  • Aluminum Rear Lower Arm Support
  • Aluminum Rear Tension Rod
  • Front Anti-Roll Bar 2.3mm
  • Rear Anti-Roll Bar 2.8mm
  • Pre-glued Brake Pad
  • Hard Anodized
  • Chassis, Damper related products,
  • Wheel Hubs & Nuts.
  • Lower Center of Gravity Fuel Tank
  • Self-Locking Wheel Nuts
  • Floating Rear Body Mount
Mugen MBX-6 chassis close shot
Part #: E0080 – Mugen Seiki MBX-6R nitro buggy
