Losi just released the good news that they will be shipping out a pre-built roller of their 1/5th scale Losi 5ive-T large scale truck! Nearly everything is complete on the truck minus the need for your choice of engine, pipe, electronics, and paint.
Losi 5IVE-T Roller Features:
- 4-Wheel Drive Power Train with All Metal Gears
- 5mm Aluminum Chassis Design Based on Successful 8IGHT Platform
- 3-Tunable Sealed Viscous Differentials
- Large-bore Shocks with 7mm Shafts/Threaded Adjusters
- Multi-Piece Beadlock Off-Road Wheels
- Aluminum Dual-Disk Braking System
- Extra-Large 800cc Fuel Tank With Clunk
- 2-Stage Air and Fuel Filter Systems
- Full Roll Cage Modeled After Full-Scale Trucks
- 4-Piece Body with Ability to Replace Individual Panels
- CV Driveshafts Used Throughout
- Innovative sealed clutch mount with cooling fins
Losi 5ive-T Specifications
Type: Short Course Truck
Scale: 1/5
Length: 38 in (965.2mm)
Width: 20.75 in (527mm)
Height: 12.25 in (311.1mm)
Ground Clearance: 2 in (50.8mm)
Wheelbase: 24 in (609.6mm)
Chassis: 5mm 6061-T6
Suspension: 4 wheel independent
Drivetrain: 4WD with 3 silicone fluid differentials
Tire Type: Off-Road all-terrain
Gear Pitch: 1.5 Module
Wheel Size: 4.75 in (120.6mm)
Kit/RTR: Rolling Chassis
Shock Type: 24mm Diameter Oil Filled with Compensation Bladders
Body: Modular Lexan Truck Body with Stickers to Apply
Ball Bearings: Included Throughout Including Steering
Fuel Tank Capacity: 800cc
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: 1-3 Hours
Is Assembly Required: Yes
Needed to Complete 5ive-T Roller:
- 2.4GHz DSM surface transmitter and receiver
- Gasoline with 2-cycle oil
- 23–29cc Gas Engine
- Tuned Pipe
- 1/5-Scale Steering Servo
- 1/5-Scale Throttle Servo
- Polycarbonate Paint
- Receiver Battery and Charger
Part #: LOSB0024 – Losi 5IVE-T Roller
MSRP: $1,099.99
