HPI Savage 3 speed tranny
HPI Savage 3 speed transmission
Bolt in this completely pre-built HPI Savage 3 speed tranny and take your HPI Savage X to the next level! You get more punch and higher top speed, the best of both worlds! Faster track times, easier wheelies, blistering top speed, better fuel mileage, and lower engine temperatures are the result of the HPI 3 speed tranny, the ultimate HPI Savage upgrade.
Internally, the HPI Savage 3 speed tranny gearbox has been redesigned for extra durability and longer life. Hardened steel is used for many of the gears and hubs, stronger clutch mechanisms were developed, as well as extensively lightened gears and hubs. The automatic shift points in the HPI Savage 3 speed tranny are pre-set at the factory, and can be manually adjusted to suit track conditions.
Complete installation instructions are included with both versions. Built to the exact factory specs for a perfect fit, the HPI Savage 3 speed transmission bolts right in to all HPI Savage trucks and is even compatible with the HPI Reverse Module.
HPI Savage 3 Speed Transmission Features:
The HPI Savage 3 speed tranny features an easy installation with no extra modification required to the gear box. The gear ration has been optimized Big Block engines using a wide variety of adjustable clutch bells and spur gears. A steel clutch holder unit is more durable than current aluminum material. The HPI 3 speed tranny also features durable Steel second and third gears.
HPI Savage 3 Speed Tranny Benefits:
  • 10% higher top speed
  • 10% more torque
  • Stronger gears
Part #: 87257 – HPI 3 speed transmission (assembled)
MSRP: $125.00
Discuss the new HPI Savage 3 speed transmission in our HPI Savage forum.
