The D8S combines everything you can want for top-level buggy racing into one convenient package – just add fuel and batteries and get on the track! The HPI D8S brings with it a World Championship-winning heritage combined with the RTR flexibility of HPI radio gear and the bulletproof Nitro Star F3.5 engine, you can easily get the best of both worlds as soon as you open the box. Race-proven by World Champions and backed by HPI, you can't go wrong with the HPI D8S.
Because the D8S chassis and suspension parts are exactly the same as the HB D8, the D8S is ready to upgrade with Atsushi Hara Edition parts from HB!
The HPI D8S RTR is fitted with the comfortable and feature-packed HPI TF-40 2.4GHz radio system for supreme control and confidence! The latest digital 2.4GHz radio technology allows you to confidently drive your HPI D8S with other drivers without worrying about things like frequencies or radio conflicts. The radio features a pistol-grip design with drop-down steering wheel, 3 channel functionality, easy carry handle, fold-down aerial, end point adjustments, servo reversing and steering dual rate. It's also extremely lightweight due to it requiring only four AA batteries. This is a fully-featured, lightweight, 3-channel radio with advanced ergonomic features and total adjustability.
HPI D8S features
- Ready to Race version of the World Champion D8 buggy
- Fitted with Nitro Star F3.5 engine
- TF-40/RF-40 2.4GHz 3-channel radio system with failsafe and drop-down steering wheel
- Powerful SB-5 steering servo
- SF-10W waterproof throttle/brake servo
- 4mm 7075 aluminium chassis with centralized weight balance
- Easy radio tray removal for maintenance and cleaning
- Composite chassis braces for extra driving feel
- Lightening cut-outs under servos, engine and clutch bell
- Tough oil-filled gear differentials
- Spiral-cut diff gears for extra durability
- Dual fiber disk brakes with easy-access adjustable linkage
- Secure forward-mounted receiver & battery box
- Unique HB solid suspension arms
- Silicone oil-filled HB Big Bore shocks with threaded aluminium bodies
- HB Inverse Steering Block Design front end
- Thick steel turnbuckles
- Total adjustability: roll centre, wheelbase, camber, sway bar and more
- Top quality HB racing wheels and tires
- Aluminium shock towers have multiple shock mounting positions
- Quick access to all critical maintenance points
- Dual bellcrank steering with aluminium drag link
- Cam type servo saver
- Large fuel tank with internal baffles
- Fuel tank clunk helps engine stay running if car is upside-down
- All socket head hardware
- Full set of rubber-sealed ball bearings
Part #: 106116 – HPI RTR D8S Buggy
MSRP: $829
