Zeroing in servos
armymedic
RCNT Rookie
Auorora, Colorado
:(Just a quick question, how do you know if you have your throttle/steering servos zeroed in correctly? I just cleaned my RS4 3 and dont know if I adjusted them correctly.
Rolex
Hoof Hearted
In Memoriam
Military Veteran
In my recliner
  2. Flying
If you didn't have the servo horns off, nothing mechanical has changed. When you run the car you might need to tweak the trim knob to center the steering while you're rolling forward slowly.
Rolex
Hoof Hearted
In Memoriam
Military Veteran
In my recliner
  2. Flying
Nothing wrong with cleaning. :D
Just to make sure, remove the center screw holding the horn on the servos. Turn on the radio and receiver to activate them. Turn the throttle trim all the way down and center the steering trim. Reattach the control horns while the carb is closed, and the steering wheels are centered.
Other than the tweaks mentioned above, you'll now be good to go.
armymedic
RCNT Rookie
Auorora, Colorado
OK cool, thank you I will do that. So I want the throttle trim all the way down on the radio? Not in the center?
Amoeba
RCNT Addict
Seattle area
All the way down as in set at neutral (center). This will allow you to adjust your idle higher/lower as needed when running your car to temporarily compensate for weather/cold engine etc. Trim settings shouldn't be used for long-term adjustments, adjust your linkages for that. Your engine will thank you :)
Rolex
Hoof Hearted
In Memoriam
Military Veteran
In my recliner
  2. Flying
Throttle trim all the way down. That's the only way you can properly set the idle and not stall the engine when you brake. The trim is only turned up to make it a little easier to start cold, and for warming it up.
Rolex
Hoof Hearted
In Memoriam
Military Veteran
In my recliner
  2. Flying
You're good to go. Keep us posted. Taking things apart and getting them set up correctly is all part of the learning process.
street silence
Replies
1
Greywolf74
Greywolf74
C
Replies
STONER RC
STONER RC
Rayzzfish
Replies
5
Greywolf74
Greywolf74
Rcjunky2002
Replies
19
cbaker65
cbaker65
