8T D5 Motor, IntelliSpeed 8T Pro Racing ECS, JR Racing XR3 Radio, TRC Foam tires (Pink rear / Purple front)
It was a great kit to build and very easy.
A couple of tips:
1. Get a 2-56 & 4-40 Tap, they only provide a 4-40 tap screw, and you'll need the 2-56 tap for the bottom plate and an GOOD hex tool, that Graphite is tough stuff!
2. Grease the turnbuckles BEFORE you begin assembly, it will make your life easier.
3. Get some Trinity shock collars, they are red (and blue) aluminum and are knurled to make shock adjustments much easier. (and lightly oil the o-ring BEFORE assembly).
4. Follow the instructions and "tweak" the chassis before you run it the first time & READJUST YOUR DIFFS AFTER YOUR FIRST RUN!
Other than that, the XXX-S Graphite ROCKS!!!!!!!!!!!
