Xtr & M2 Compound Tires
WHY RESPOND IF YOU KNOW THE ANSWER TO THE QUESTION? (NOT MET TO BE RUDE)
Yea I know the diffrence I will be glad to tell you if you stop yelling. Also I was simply asking what was the nead for duplicate posts?
This from Pro-line
What is the difference between M2 and M3 compound?
a) M3 is the much softer compound of the two and is used when more traction is desired
XTR compound provides very good traction and longer wear than softer compounds.
XTR is Harder than M2
M3 is so soft it is only ran on Cars and 10th scale 2.2 tires...X
Simply stated and don't take this personal you are new to the forum and double posts are not needed or liked here. I was very nice in the way I said it some guys would come out and start blasting you. I was simply asking a question so you might see the error in your ways since you were new to the forum.. On the main page under your name you will see a link that says view all new posts. That is what the majority of the users here click on to view posts so a dupe post sticks out like a sore thumb. Anyway welcome and I am glad to help on the tire question. X
