XTM 247 engine
craig911
Bristol, England
hi guys i just bought a xtm 247 engine and the air intake in the carb is small compaired to my AR .21
would it be ok to change the carb or should i just keep the stock one
thanks in advanced craig
Craig, I don't have the technical knowledge that people who design these engines have but in my opinion, I don't think you have anything to gain by just changing the carb to a larger one. I'm sure that a lot of research went into determining what size carb to use to obtain maximum performance. As with any engine, just changing one thing without changing the others effected by the change usually results in no improvement. Increasing the size of the carb does no good unless the engine can flow the additional air available and may result in being detrimental to the performance.
Many carbs come with Venturi inserts of different sizes to adjust the power output and fuel consumption. If you have a larger bore carb that fits the engine block correctly you might increase engine performance. Doesn't hurt to try if the carb fits the engine
i bought the engine off ebay with loads of extras brand new just broken in ( and it shows tones of compression and the engine insides are immaculate )
they included a spare carb off of a SH engine that has a slightly bigger bore but its still smaller than my AR .21 carbs bore
thanks for the info i will try it stock then increase size accordingly and see what happens
And so? Did you try changing carbs and if you did, did it work?
I'm taking my car out today after tuning the engine just right & it has tones of power with the stock carb so i will keep it as is,
thanks for the info every one i will probably do a carb swap once i require more power
The carb on the 24.7 is a decent carb. I'd leave it as is. I've had 2 or 3 of those engines and while they aren't the most powerful thing out there, they are pretty reliable for 6 gallons or so, then their pinch gets pretty weak and the OWB starts slipping.
X
Replies
15
1K
Nitroman7888##
Nitroman7888##
R
Replies
3
2K
tudordewolf
tudordewolf
T
Replies
3
kolby611
kolby611
normrdz300
Replies
4
3K
normrdz300
normrdz300
TheBeastsOwner
Replies
TheBeastsOwner
TheBeastsOwner
