knights
I have a old 4910 pro 15 truck and a another I built on ebay. It has the wide rpm arms and is low to the ground. You cannot roll it. It sticks Great. I am also building a Extended chasis to put the Picco .26 on. I want to go ahead and get 2 new engines for the older trucks. The wide stance truck could handle a bigger motor. I was thinking maybe a traxxas 2.5 for one and a dynamite .19 for the other. Both are cheap engines price wise. The dynamite I found is $110.00, but It will need atleast a pull starter and engine mount and every thing on the cutch side of the engine. Might have to get some parts for the linage also, not sure. I have the tmaxx pro 15 mount if it will work and also the pullstater if it will work. I also have all the cutch side of the pro 15 if it will work on the dynamite. If these things don't work, I might have $160.oo or more into it and the picco 26 is not much more than that. I don't think my stock trucks could hand the .26 though, that is why I am building the X chasiss. I would like to know what engines can I get for my older 2 trucks that would be as cheap as I could go. I want a engine big enough so that it don't get to hot pushing this big ol monster trucks around. The pro 15 seems to be working hard to push the trucks. What engines should I go with on the short stance truck? I would consider going back with the pro. 15 on the short stance truck if I could get a different heat sink that would help keep the heat down. The fuel I run says 10% oil. Most engines say run 18% oil content. What engine should I go with on the Wide stance truck? Thanks. I love this site........
