Webbage
I'm trying to plan a Wheely King crawler conversion. I'm a bit bamboozled by all the trick parts available from the US and don't want to make any mistakes as I'm in the UK and importing the stuff is time consuming.
My Plan so far is to take the WK from stock using these parts:
TRA4928X - Traxxas Output Yokes (EMX,TMX.15,2.5,3.3)
TRA4951X - Traxxas Heavy-Duty Drive Shaft (EMX, TMX, TMX2.5)
ST85252B - ST Racing Concepts Aluminum Hub Carrier (Blue) (Wheely King)
ST85256S - ST Racing Concepts Aluminum Front & Rear Shock Towers (Silver) (Wheely King)
ST85257B - ST Racing Concepts Complete Aluminum Steering Linkage Upgrade Kit (Blue) (Wheely King)
ST85264CB - ST Racing Concepts Extended Wheelbase Rock Crawling Kit (Blue) (Wheely King)
AXI30500 - Axial Heavy Duty Differential Locker
I am also looking at:
Novak Rooster Crawler ESC
Novak Fifty-Five 55T motor
But I have to get these in the UK (more pricey but I keep my UK warranty )
That ought to get me started I'm thinking. But there are some niggling things that worry me about the setup...
I want to axle-mount the steering servo, to remove the flex in the steering system, and also to allow me to easily flip the setup around so the battery is at the front. If I get a multi-channel radio set I may even convert it to 4-wheel steering . I looked at this This Steering Kit from Mico/rcguy and it looks like the ideal solution, but I have a question. It says you need to turn the shock/link mounts through 90-degrees.
I found that plate on, HERE, has the shocks mounted weird on the stock axle mounts. Wouldn't that strain the mounts in funny directions?
I'm unlikely to compete with this truck (I'm learning the ins and outs on this beast atm, then I'll purpose build one if I want to get serious).
Is there anything else you guys would suggest for add-ons or mods?
