what car should i get?
JdiDDy399
I'm looking for a on road car but which one? I need a fast one! speed is the best thing.:banana:
:stupid:
the new traxxas 4-tec has a claimed top speed of 60+ mph this is scary fast. My street force is a hand full at around 52 mph. I wonder what this thing would be like.
Well, I did a lot of looking before I picked up my AE Nitro TC3 2speed 4wd. With the right getup, this car has and will do 70+. I have decided to go with the MT .12 Big Head. Mugen Seiki mill. Essentially a Nova Rossi. Italian made. Steady under 200 degrees F.. 5 port. Etc Etc.
Anyhow, if you have a programmable TX or one you would like to use. Then get the kit car. I got the 2031. 4wd 2speed. Made for rear exhaust bump start mills. But get the model for your needs.
As far as electrics, Novak XXTra Synth. FM RX, Futaba 'standard' servos to start with. Then I go to the HiTec servo that I will need for the job. I wont know that until I have driven it for a while though.
Foams are good for onroad. Most come premounted and trued. Which takes a lot of guess work out of proper tire mounting. Something that truel affects performance. 60/40 front/back should be a good overall foam density to start with.
Start with stock suggested settings first. THEN, start messing with it. Only one thing at a time and see how it affects performance.
Hope this helps.
-Chris
YEA YEA representin tha tc3 all the way. simplicity at its best and no belts to replace. also its a full bred racer and speed is is just a throttle pull away:)
M
Replies
21
turbo27
turbo27
sean p
Replies
28
1K
WutUp Clegg
WutUp Clegg
WickedFog
Replies
35
bigbristv
bigbristv
lambdapriest
Replies
8
1Outlawtrucker
1Outlawtrucker
